  • 80PG7WA 3" Green-Cone Full-Range Speaker 16 Ohm
BUYOUT 80PG7WA 3" Green-Cone Full-Range Speaker 16 Ohm
Factory BuyoutsPart # 299-4342
Model: 80PG7WA
The 80PG7WA 3" Green-Cone Full-Range Speaker utilizes a one-piece paper cone and surround, neodymium magnet and 16 ohm impedance.
  • 16 ohm impedance
  • Unique green-colored cone
  • Neodymium magnet for a small, lightweight stature
BUYOUT $0.44
MSRP: $0.88
Save $0.44 (50%)
6618 In Stock
We'll send you an email when 80PG7WA 3" Green-Cone Full-Range Speaker 16 Ohm is back in stock or available for preorder.
The 80PG7WA 3" Green-Cone Full-Range Speaker utilizes a one-piece paper cone and surround, neodymium magnet and 16 ohm impedance. With an extended response and unique green-colored cone, this would be a great candidate for use in multiples.
BrandCoast Buyouts
Model80PG7WA
Part Number299-4342
UPC848864074146
Weight0.15
Nominal Diameter3"
Power Handling (RMS)1.6 Watts
Power Handling (MAX)3.2 Watts
Impedance16Ω
Frequency Response200 to 12,000Hz
Sensitivity81.41dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)193Hz
DC Resistance (Re)15.55Ω
Mechanical Q (Qms)9.419
Electromagnetic Q (Qes)8.104
Total Q (Qts)4.356
Compliance Equivalent Volume (Vas)0.0356ft³
Diaphragm Mass Inc. Airload (Mms)0.8639g
Maximum Linear Excursion (Xmax)0.25mm
Surface Area of Cone (Sd)30.19cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Magnet MaterialNeodymium
Overall Outside Diameter3.0625"
Baffle Cutout Diameter2-13/16"
Depth1"
