  • 800 Hz Low Pass 4 Ohm Crossover
Parts ExpressPart # 266-448
Convenient crossovers that work great in any application requiring economical and flexible filtering.
Your Price: $11.99
Save $4.00 (25%)
56 In Stock
We'll send you an email when 800 Hz Low Pass 4 Ohm Crossover is back in stock or available for preorder.
Convenient crossovers that work great in any application requiring economical and flexible filtering. Also for use in car stereo installations with component speaker systems. Low pass, band pass, and high pass models complement woofers, midranges, and tweeters. Designed to be wired in-line between amp and speaker by using .205" disconnect terminals or soldering. The crossovers' compact size facilitates mounting virtually anywhere you desire.
Specifications: • Approximately 250 watts RMS • Type: Low pass • Driver impedance: 4 ohm • Crossover frequency: 800 Hz • Roll off: 12 dB • Overall dimensions:120mm L x 48.5mm W x 36 mm H.
Part Number266-448
UPC844632074882
Weight0.5
Crossover TypeLow Pass
