  • Factory Pull 7.5V 1A DC Power Supply AC Adapter with 1.35 x 3.5mm Center (+) Positive Plug
CLEARANCE Factory Pull 7.5V 1A DC Power Supply AC Adapter with 1.35 x 3.5mm Center (+) Positive Plug
Factory BuyoutsPart # 129-201
Model: FA-0751000SUA
These power supplies were pulled from routers and other network equipment that were returned to the factory for replacement. They work great and were 100% QC’d. Their loss is your gain. Being sold for less than factory cost!
  • Tested for reliability, deeply discounted, preowned power supply
  • Wide 100 ~ 240 VAC @ 50/60Hz input for international use
  • Economical price
  • Right angle AC prongs avoid covering up another outlet on the wall
We'll send you an email when Factory Pull 7.5V 1A DC Power Supply AC Adapter with 1.35 x 3.5mm Center (+) Positive Plug is back in stock or available for preorder.
This adapter is perfect for low budget, low power audio projects. Use the 1.35 x 3.5 mm center positive plug or cut off to power an electronic project. At this low price they won't last long.
Check all your routers and Ethernet switches to see if you can use this power supply as a replacement or backup power supply. This AC adapter is the original power supply for some Netgear products.
Specifications: • Power output: 7.5 V 1A • Power input: 100~240 VAC, 50/60 Hz. Output connector: 1.35 mm x 3.5 mm x 7 mm, center positive • Cable length: 6 ft.
BrandFactory Buyouts
ModelFA-0751000SUA
Part Number129-201
UPC844632009433
Weight0.2
Center/Tip PolarityCenter Positive
Current Capacity1000mA
DC Output Voltage7.5V
Input Voltage100~240 VAC
Plug Size1.35 x 3.5 mm
