  • 7/8" x 2" 3.5W Speaker 8 Ohm 78T494-511-Y-PAR
BUYOUT 7/8" x 2" 3.5W Speaker 8 Ohm 78T494-511-Y-PAR
Factory BuyoutsPart # 289-2110
Model: 78T494-511-Y-PAR
mount brackets for easy mounting.
  • The gasket on the front of the woofer allows the woofer to seal completely when rear-mounted
  • Simple side mounting tabs paired with the sealing gasket allow an easy installation in many projects
  • The 8 Ohm impedance of each woofer mates well to most amplifiers
BUYOUT $1.82
3168 In Stock
We'll send you an email when 7/8" x 2" 3.5W Speaker 8 Ohm 78T494-511-Y-PAR is back in stock or available for preorder.
Order in the next 15 hr 0 min to ship today. Details
The 78T494-511-Y-PAR is a pair of woofers that are connected to a simple plug. The mounting tabs and gasket make this speaker pair easy to mount. The 8 ohm impedance of each woofer means that you have wide assortment of amplifiers to choose from.
BrandFactory Buyouts
Model78T494-511-Y-PAR
Part Number289-2110
UPC848864047775
Nominal Diameter1 x 2"
Power Handling (RMS)3.5 Watts
Power Handling (MAX)8 Watts
Frequency Response370 to 12,000Hz
Sensitivity73.5dB 2.83V/1m
Resonant Frequency (Fs)366.7Hz
DC Resistance (Re)7.057Ω
Voice Coil Inductance (Le)0.08799mH
Mechanical Q (Qms)4.397
Electromagnetic Q (Qes)7.691
Total Q (Qts)2.798
Cone MaterialPoly
Overall Outside Diameter3.14 x 1"
Baffle Cutout Diameter2.3 x 1"
Depth0.36"
# Mounting Holes2
