  • Lightning MFi to USB A Durable Braided Charging and Sync Cable 6 ft. Black
CLEARANCE Lightning MFi to USB A Durable Braided Charging and Sync Cable 6 ft. Black
Parts ExpressPart # 130-630
Enjoy all the same charging and data performance from apple branded lightning cables for a fraction of the price. The extra length and durability of this 6 ft. MFI certified cable gives you the freedom and piece-of-mind that shorter cables don't provide.
  • Extended strain relief (SR) design for better durability and ruggedness
  • Made for iPod, iPhone, and iPad -- MFI certified lightning cable
  • Pull-resistant cross knit fibers
  • Aluminum plug cover resists high temperatures and electromagnetic interference
  • 6 ft. length provides you with more freedom while your device is charging
We'll send you an email when Lightning MFi to USB A Durable Braided Charging and Sync Cable 6 ft. Black is back in stock or available for preorder.
Maintain control of your apple device when it's charging while you relax on the couch or in bed. Shorter, standard issue cables take you away from your device while it is charging, but with this 6 ft. lightning cable you can still use your iPhone, iPad, or iPod when charging. Meeting strict apple standards, this lightning cable from Parts Express will sync your device to your computer just like the more expensive apple branded lightning cables.
This lighting cable stands-up to the abuse charging cables go through every day. It has an aluminum cover that cools down charging heat and blocks electromagnetic interference. The rugged extended strain relief and pull-resistant cross knit fibers keep the internal conductors from breaking down even when bent 30,000 times at a 60° angle, and pulled with 50 kg of tension. The plug's extended strain relief is perfect for connecting and disconnecting from your device without taking the cover off.
Part Number130-630
UPC848864055589
Weight0.15
Cable Length6feet
Cable TypeUSB to iPhone iPad iPod
Jacket ColorBlack
