  • 2.1 x 5.5mm DC Male to Female Extension Cable 22 AWG 6"
CLEARANCE 2.1 x 5.5mm DC Male to Female Extension Cable 22 AWG 6"
Parts ExpressPart # 090-993
This coaxial plug to jack extension cable works perfect for making your existing 2.1 x 5.5 mm AC/DC adapter longer. The small extension connector hides under base boards, door trims, and carpet.
  • 6" long for internal extensions in projects or external for just a little extra
  • Standard 2.1 x 5.5 mm plug and jack
  • Extension connection is easily concealed
CLEARANCE $0.87
Save $2.12 (71%)
1 In Stock
We'll send you an email when 2.1 x 5.5mm DC Male to Female Extension Cable 22 AWG 6" is back in stock or available for preorder.
Order in the next 12 hr 15 min to ship today. Details
Why use a gaudy AC extension cord to add to your power adapter? This puts the AC adapter box and the AC plug in an awkward position right where everyone can see it. This coaxial plug and jack extension keeps the adapter box in the AC outlet on the wall and the extension connection is practically unnoticeable. The connection is small enough to hide under baseboards or in small conduits.
Works great in the vehicles too! Any device that uses a 2.1 x 5.5 mm cigarette lighter/accessory cord has the ability to be extended and connection hidden under door trims and carpet. Protect the connection from dust, moisture, and accidently pulling apart with 1/2" (12 mm) heat shrink tubing.
Part Number090-993
UPC848864049250
