  • 5-Piece Soldering Iron Kit with LED Christmas Tree Kit Bundle 320-1661
CLEARANCE 5-Piece Soldering Iron Kit with LED Christmas Tree Kit Bundle 320-1661
Parts ExpressPart # 320-1661
Add some holiday cheer to your office or home with the 5-Piece Soldering Kit and Christmas Tree Bundle. The easy to assemble project kit, a three-dimensional Christmas tree with 16 flashing red LEDs will brighten any Scrooge's holiday. The bundle also includes a 5-piece soldering kit with everything you need to complete a successful solder job that requires a 30-watt soldering iron.
  • Christmans Tree features 16 flashing LEDs grab your attention
  • Tree is powered by a 9 volt battery, not included, works as a tree stand
  • 5-piece soldering iron kit includes versatile 30 watt soldering iron, solder, soldering iron holder, rosin, and an extra tip
  • Add holiday spirit with the all-in-one, easy to assemble kit
Add Holiday Spirit
Add some holiday cheer to your office or home. A three-dimensional Christmas tree with 16 flashing red LEDs will brighten any Scrooge's holiday. If you want to customize your tree with some added color, the kit includes extra green and yellow LEDs. Hang the tree or set it on a flat surface; the 9V battery acts as a stable base. Soldering is required to complete the kit. Operates on one 9V battery (not included) or 12V DC via an external power supply. Dimensions: 3.1" W x 3.5" D x 4" H.
Complete Soldering Kit
If you're just getting started, or need to do a quick fix, this 5-piece kit has everything you need to complete a successful solder job. The rosin cleans the components being soldered together, the iron and solder work together welding the parts together, and the soldering stand holds the iron while it heats up and when not in use. This kit also includes an extra tip for the everyday user.This 5-piece soldering kit is a great value for the beginner or occasional user.
Part Number320-1661
UPC848864071060
Weight0.68
