  • 5-Pack LED Lighting Strip 4-Pin Male to Male Connector
Parts ExpressPart # 073-111
Quickly connect two LED lighting strips together, or repair a strip to LED controller connection with this 4-pin, male-to-male connector.
  • Quickly connects 4-pin RGB LED light strips together
  • Economical 5-pack
Your Price: $0.25
MSRP: $1.99
Save $1.74 (87%)
175 In Stock
We'll send you an email when 5-Pack LED Lighting Strip 4-Pin Male to Male Connector is back in stock or available for preorder.
Connect two LED lighting strips together, or replace damaged controller to lighting strip connections with this 4-pin male-to-male connector.
Designed for strips and controllers that are pre-terminated with female sockets, this male-to-male connector features an overall width of 8 mm, outside pin to outside pin. Pin-to-pin spacing is 2.5 mm. Sold in packs of 5.
Note: When directly connecting multiple LED strips together using this 4-pin male-to-male connector, it is important not to exceed a total series length of 33 feet. Doing so can damage some controllers, power supplies, and cause resistors within the LED lighting strip to overheat, creating a color difference between strips.
Part Number073-111
UPC848864058023
Unit of MeasurePackages
Weight0.03
