  • Guitar/Amp Knobs for Knurled/Spline 6mm Split Shaft with White Indicator 5-Pack
CLEARANCE Guitar/Amp Knobs for Knurled/Spline 6mm Split Shaft with White Indicator 5-Pack
Parts ExpressPart # 240-2205
These small black ribbed knobs put the perfect finishing touch on your amplifier or other project. Basic fluted design, measures 0.59" diameter x 0.68" height (14.8 x 17.3 mm). Pressure fits for use with 6 mm knurled shaft potentiometers; white top with full white line indicator.
  • White top and full white line for better visibility
  • Economical 5-pack
  • Pressure fits over 6 mm knurled shaft potentiometers
CLEARANCE $2.10
Save $2.89 (58%)
99 In Stock
We'll send you an email when Guitar/Amp Knobs for Knurled/Spline 6mm Split Shaft with White Indicator 5-Pack is back in stock or available for preorder.
Order in the next 7 hr 1 min to ship today. Details
These small black ribbed knobs put the perfect finishing touch on your amplifier or other project. Basic fluted design, measures 0.61" diameter x 0.59" height (15.5 x 15 mm). Pressure fits for use with 6 mm knurled shaft potentiometers; white top with full white line indicator.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Part Number240-2205
UPC848864068008
ColorBlack
