  • 12 Volt Warm White LED Lead Lamp for Marantz Sansui Kenwood Yamaha Sony 5 Pack
Parts ExpressPart # 070-130
Rejuvenate your vintage stereo receivers without worrying that you will be replacing the lamps again. These LED 12 volt lead lamps provide a warm white glow for tuner dials, level meters, and LCD displays so your vintage equipment will come back to life.
  • Popular in vintage Marantz, Sansui, Kenwood, Yamaha, Sony, and other classic stereo receivers
  • Amp runs cooler compared to incandescent bulbs
  • Saves energy by drawing only 20 mA vs. 35 mA with standard bulbs
  • Bi-polar for quick installation
  • Versatile 12 volt AC or DC operation
  • Economical 5-pack
Your Price: $7.79
MSRP: $8.99
Save $1.20 (13%)
173 In Stock
We'll send you an email when 12 Volt Warm White LED Lead Lamp for Marantz Sansui Kenwood Yamaha Sony 5 Pack is back in stock or available for preorder.
These 12 volt LED lead lights' design solder right in to the original bulb's location in Marantz, Sansui, Kenwood, Yamaha, Sony, and other classic stereo receivers. Manufacturers used lead style incandescent lamps to back light tuner and panel displays in stereo amplifiers. Using LED lights to replace original burnout incandescent bulbs saves energy and practically illuminates having to replace the bulbs in the future. You will fall in love with your stereo receiver all over again once you install these new LED lights.
These LED lead lamps have multiple application possibilities, because they can work with 12 volt AC or DC and their long leads provide multiple mounting options away from the power source. Many cars use these lead lamps to light up dash instrument panels and car stereo displays. It's more efficient to replace incandescent bulbs with LED lights to save the hassle of having to replace them again. If your vehicle has a power surge or likes off road driving the LEDs are less likely to burn out like standard filament bulbs. You will also find them backlighting LCD displays in portable and desk style communication radios. Next time a repair or a new project needs a lead light, use an LED lamp.
Use LED lights to create lighting effects in small models and as LED indicator lights. Their versatile working voltages make them perfect for headlights on model cars and status lights for power supplies.
Specifications: • LED dimensions: 0.24" H x 0.17" Dia. • Wire length: 20 " x 2 • Color: Warm white • Brightness: 30 LM • Recommended voltage: 12 volts @ 20 mA • Working voltage: 3 to 15 volts.
Part Number070-130
UPC848864032832
Unit of MeasurePackages
Weight0.04
