  • 4-Way Binding Post in One Horizontal Mount for Speaker Amplifier
CLEARANCE 4-Way Binding Post in One Horizontal Mount for Speaker Amplifier
Parts ExpressPart # 260-316
Looking to enhance your two-channel audio project with four binding posts? Look no further! We have just the solution for you. Our specially designed panel allows you to easily replace or add four binding posts to your project, whether you want to mount it inside or outside.
  • Top plastic 0.65" knob doesn't screw off to prevent misplacement
  • Shaft hole bare wire and banana jack hookup for versatility
  • Small 2.92" x 0.94" footprint for small enclosures
  • Plastic body insulates the binding post from metal panels
  • Shaft hole accepts up to 12 AWG stranded wire for large wattage projects
  • 3/4" center to center spacing for dual banana plugs
We'll send you an email when 4-Way Binding Post in One Horizontal Mount for Speaker Amplifier is back in stock or available for preorder.
With our versatile design, you have the flexibility to choose the perfect location for your binding posts. If you prefer a clean and seamless look, simply mount the panel inside your project. This way, the binding posts will be neatly integrated, maintaining the sleek appearance of your audio setup.
On the other hand, if you want easy access and visibility to your binding posts panel, mounting the panel outside your project is the way to go.
Don't let the installation process intimidate you. Easily mount the binding post panel with #3 screws and #8 ring terminals (sold separately). Whether you're a seasoned DIY enthusiast or a beginner, you'll find the process straightforward and hassle-free.
Part Number260-316
UPC848864074313
Weight0.1
Contact PlatingNickel
Style / TypeMounting Plate
