  • 12V Waterproof Relays 40A 4-Pack 5-Pin with Wiring Harness and Metal Mounting Bracket
CLEARANCE 12V Waterproof Relays 40A 4-Pack 5-Pin with Wiring Harness and Metal Mounting Bracket
Parts ExpressPart # 330-086
Model: YAE-SS-112D waterproof
This waterproof 12 VDC SPDT relay kit includes four rugged 5-pin Bosch-style relays (40 A) with metal mounting brackets, plus four pre-assembled wire harnesses for plug-and-play installation. Designed for demanding under-hood and outdoor applications, each relay features a sealed plastic housing to resist moisture, grime, and corrosive elements. Streamline your automotive or marine electrical projects with this all-in-one, ready-to-install relay and harness solution.
  • All-in-One Kit: Four waterproof relays plus four custom wire harnesses included.
  • Reliable SPDT Switching: 5-pin Bosch-style relays rated at 40A for heavy-duty performance.
  • Durable Construction: Sealed plastic housing with metal mounting brackets—for protection and easy installation.
  • Plug-and-Play Harnesses: Pre-wired connectors allow fast, error-free setup
  • Ideal for Harsh Environments: Waterproof design makes it perfect for automotive and outdoor electrical systems.
We'll send you an email when 12V Waterproof Relays 40A 4-Pack 5-Pin with Wiring Harness and Metal Mounting Bracket is back in stock or available for preorder.
1. All-in-One Kit
This kit streamlines installations by bundling four relays with matching wire harnesses, saving you the hassle of shopping for components separately. Whether you're wiring multiple accessories or building a complex control setup, everything you need is right in the box. This cohesive package guarantees consistency and compatibility across all four relay assemblies, simplifying both installation and maintenance.
2. Reliable SPDT Switching
Each relay in the kit is a standard 5-pin, single-pole double-throw (SPDT) Bosch-style design, capable of handling high currents—40 A. This makes it versatile enough for a wide range of applications, from powering lighting to controlling high-demand accessories. The SPDT configuration gives you both normally open and normally closed options, offering flexibility in circuit design.
3. Durable Construction
Built to withstand tough environments, each relay’s sealed plastic housing provides excellent protection from moisture, dust, and road debris. The included metal mounting tab allows quick and secure fastening under the hood, behind dash panels, or in marine compartments. This rugged construction ensures long-lasting performance even in extreme conditions.
4. Plug-and-Play Harnesses
The included wire harnesses come pre-assembled with standard automotive connectors that match the relay pins precisely, making installation as simple as plugging in. This plug-and-play design reduces installation time and errors, making it ideal for both professionals and hobbyists. Color-coded wires and clear labeling further enhance the user experience, ensuring quick and correct connections.
5. Ideal for Harsh Environments
Thanks to the waterproof sealed housing and sturdy metal brackets, these relay kits are tailor-made for environments exposed to water, oil, vibration, or extreme temperatures. Whether you're wiring winches on your off-road rig, pumps on your boat, or lighting on a commercial vehicle, this kit can handle the elements. Its reliable construction offers peace of mind in applications where durability and performance are critical.
ModelYAE-SS-112D waterproof
Part Number330-086
UPC848864079516
Weight0.78
