  • 3.5mm Stereo Gold Plug with Nickel Metal Shell 4-Pack
Parts ExpressPart # 090-516
Solder these gold plated 3.5 mm plugs with 8.5 mm metal shell to 2-conductor wire plus shield for long lasting connectivity. These stereo 3.5 mm plugs work perfect for replacing worn out plugs on headphones and AUX cables.
  • 6 mm gold plated collar behind the 3.5mm connector fits smartphones and other audio players without removing their protective covers
  • 8.5 mm outer metal shell adds more shielding and durability
  • Gold plated 3.5 mm male plug provides long lasting connectivity
  • Rear wire entry up to 6mm outer diameter for flexibility
  • Economical 4-pack
Your Price: $6.19
MSRP: $7.99
Save $1.80 (23%)
Quantity:Qty: 1-3 $6.19/ea
Quantity:Qty: 4+ $5.68/ea
47 In Stock
We'll send you an email when 3.5mm Stereo Gold Plug with Nickel Metal Shell 4-Pack is back in stock or available for preorder.
Solder these gold plated 3.5 mm plugs with 8.5 mm metal shell to 2-conductor wire plus shield for long lasting connectivity. These stereo 3.5 mm plugs work perfect for replacing worn out headphone plugs. The 6mm rear wire entry fits most current headphone cables, and auxiliary cables for easy replacement. Gold plated plug and metal shell upgrades the quality and durability of your current cables and gives self-made cables a professional look.
Part Number090-516
UPC848864065069
ConductorsStereo TRS
GenderMale
Mounting TypeCable Mount
