  • 4 Female Binding Post in One Mount for Speaker Amplifier
Parts ExpressPart # 260-315
Looking to enhance your two-channel audio project with four binding posts? Look no further! We have just the solution for you. Our specially designed panel allows you to easily replace or add four binding posts to your project, whether you want to mount it inside or outside.
  • Removable top plastic 0.75" cap, with 0.45" metal threads, for ring terminal installation
  • 0.75" L x 0.16" W x 0.03" thick terminals reach deep into wooden enclosures for external mounting
  • Slot bare wire and banana jack hookup for versatility
  • Small 1.81" x 1.45" footprint for small enclosures
  • Plastic body insulates the binding post from metal panels
Your Price: $1.49
Save $0.50 (25%)
84 In Stock
We'll send you an email when 4 Female Binding Post in One Mount for Speaker Amplifier is back in stock or available for preorder.
With our versatile design, you have the flexibility to choose the perfect location for your binding posts. If you prefer a clean and seamless look, simply mount the panel inside your project. This way, the binding posts will be neatly integrated, maintaining the sleek appearance of your audio setup.
On the other hand, if you want easy access and visibility to your binding posts, mounting the panel outside your project is the way to go. This way is more convenient since the 0.75" terminals reach through wooden sheets less the 0.75" thick.
Don't let the installation process intimidate you. Easily mount the binding post panel with #3 screws and connect the wires with 0.187" quick disconnects (both sold separately). Whether you're a seasoned DIY enthusiast or a beginner, you'll find the process straightforward and hassle-free.
Specifications: • Plate dimensions: 1.8" H x 1.45" W x 0.175" thick • Total depth without rear terminals: 1.2" • Mounting holes: 0.08" Diameter and spaced 0.39" appart to center• Banana hole spacing: 0.75" between the red to red and black to black to center, and 1" between black and red to center.
Part Number260-315
UPC848864074306
Contact PlatingNickel
Style / TypeMounting Plate
