CLEARANCE 3M Double-Sided Super Strong VHB Gray Acrylic Foam Tape 10mm x 0.8mm x 3m
- Double sided adhesion and closed cell foam replaces worn out speaker cabinet gaskets for high strength and long-term durability
- Only 0.032" thick makes it almost invisible behind panels
- Acrylic adhesive material with foam bonding enables it to hold up to 20 lb/in
- Strong enough to replace mechanical fasteners (rivets, welding, screws) or liquid adhesives
- Fast and easy-to-use permanent bonding method
- Creates a permanent seal against water, moisture and more
- Convenient 9.9 ft. roll
We'll send you an email when 3M Double-Sided Super Strong VHB Gray Acrylic Foam Tape 10mm x 0.8mm x 3m is back in stock or available for preorder.
