  • DC 36V 5A 5000mA 180W Switching Power Supply AC Adapter - 2.5 x 5.5mm Center Positive Plug 100~240V
Parts ExpressPart # 120-063
Get more wattage from your amplifier boards and mini amplifiers that handle up to 36V DC with this 5A AC adapter. Include this 180 watt output AC adapter in your next power hungry audio project.
  • Standard 2.5 x 5.5 mm tip positive plug
  • 36V DC 5A for power hungry amp boards and mini amplifiers
  • Certified level VI for standby power savings
  • FCC, CE certified and UL listed for safety
Your Price: $39.98
Save $41.01 (51%)
33 In Stock
We'll send you an email when DC 36V 5A 5000mA 180W Switching Power Supply AC Adapter - 2.5 x 5.5mm Center Positive Plug 100~240V is back in stock or available for preorder.
This 36V DC 5A AC adapter has the voltage and current high power amp boards and mini amps hunger for. It will deliver up to 180 watts continuously without backing down. If you have a 2.5 x 5.5 mm tip positive socket this adapter will plug right into it eliminating loose or exposed external bare wires. This makes building a 36 VDC audio project so much easier, smaller, and lighter because there is no bulky heavy transformer to deal with.
Specifications: • Input voltage: 100~240 VAC 50/60 Hz • Input current: 3A max • Output Voltage: 36 VDC • Current output: 5A • Power range: 180 watts • DC output cord: 3-7/8 ft. with 2.5 mm x 5.5 mm center positive plug • AC input cord: 4 ft. • Dimensions: 6.6" L x 2.8" W x 1.6" H.
Part Number120-063
UPC848864046037
Weight1.6
Center/Tip PolarityCenter Positive
Current Capacity5000mA
DC Output Voltage36V
Input Voltage100~240 VAC
Plug Size2.5 x 5.5 mm
