  • 30 Watt Electric Automatic Desoldering Pump Tool with Pushbutton Action
Parts ExpressPart # 370-325
Eliminate the hassle of using a separate soldering iron and desoldering pump with this convenient electric 30 watt desoldering tool. Just heat up the solder joint and push button to quickly remove solder. 3 wire grounded tip design. Replacement tip #370-327.
Your Price: $34.98
Save $8.01 (19%)
We'll send you an email when 30 Watt Electric Automatic Desoldering Pump Tool with Pushbutton Action is back in stock or available for preorder.
Eliminate the hassle of using a separate soldering iron and desoldering pump with this convenient electric 30 watt desoldering tool. Just heat up the solder joint and push button to quickly remove solder. 3 wire grounded tip design. Replacement tip #370-327. Length: 10".
Part Number370-325
UPC844632013508
Weight0.4488
