  • 3" 580325-5 3W Mini Green Paper Cone Speaker 16 Ohm Case Qty 100
Factory BuyoutsPart # 299-4177
Model: 580325-5
This 3" 580325-5 3W green paper cone full-range speaker is perfect for the hobbyist or tinkerer.
  • Stylish and unique green paper cone
  • Coated paper surround for a non-resonant response
  • Neodymium motor for light weight efficiency
  • Less than 1" deep for shallow mounting applications
Your Price: $49.88
165 In Stock
With a unique mint-green colored paper cone, this 3" full-range speaker is a great choice for the electronic hobbyist or tinkerer. A coated paper surround, 1/2" voice coil on paper former and oversize spider make for a very smoot response from 180 - 10,000 Hz, while the neodymium magnet and extremely low moving mass help boost sensitivity. Its 16 ohm impedance means it can be used in multiples for arrays and with numerous wiring configurations. Case of 100 pcs.
BrandFactory Buyouts
Model580325-5
Part Number299-4177
UPC848864075228
Weight20
Nominal Diameter3"
Power Handling (RMS)2 Watts
Power Handling (MAX)4 Watts
Impedance16Ω
Frequency Response180 - 10,000Hz
Sensitivity83.73dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)184.9Hz
DC Resistance (Re)14.4Ω
Mechanical Q (Qms)3.696
Electromagnetic Q (Qes)5.942
Total Q (Qts)2.279
Compliance Equivalent Volume (Vas)0.051ft³
Diaphragm Mass Inc. Airload (Mms)0.8436g
Surface Area of Cone (Sd)34.21cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Magnet MaterialNeodymium
Baffle Cutout Diameter2.75"
Depth1.25"
