  • 3" 580325-008 3W Mini Black paper Cone Speaker 16 Ohm Case Qty 100
Factory BuyoutsPart # 299-4179
Model: 580325-0008
This 3" 580325-5 3W black paper cone full-range speaker is perfect for the hobbyist or tinkerer.
  • Neodymium motor for light weight efficiency
  • Coated paper surround for a non-resonant response
  • Less than 1" deep for shallow mounting applications
Your Price: $49.88
17 In Stock
Order in the next 0 hr 45 min to ship today. Details
With an un-treated black paper cone, this 3" full-range speaker is a great choice for the electronic hobbyist or tinkerer. A coated paper surround, 1/2" voice coil on paper former and oversize spider make for a very smoot response from 180 - 10,000 Hz, while the neodymium magnet and extremely low moving mass help boost sensitivity. Its 16 ohm impedance means it can be used in multiples for arrays and with numerous wiring configurations. Case of 100 pcs.
BrandFactory Buyouts
Model580325-0008
Part Number299-4179
UPC848864075259
Weight20
Nominal Diameter3"
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Impedance16Ω
Frequency Response180 - 10,000Hz
Sensitivity83.34dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)175.8Hz
DC Resistance (Re)14.78Ω
Mechanical Q (Qms)4.717
Electromagnetic Q (Qes)5.799
Total Q (Qts)2.601
Compliance Equivalent Volume (Vas)0.052ft³
Diaphragm Mass Inc. Airload (Mms)0.9038g
Surface Area of Cone (Sd)34.21cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Magnet MaterialNeodymium
Overall Outside Diameter3"
Baffle Cutout Diameter2.75"
Depth1.125"
