  • 3-5/8" x 3-1/8" Rectangular Banana Jack Terminal Cup
BUYOUT 3-5/8" x 3-1/8" Rectangular Banana Jack Terminal Cup
Factory BuyoutsPart # 269-2114
Give your speaker projects a professional finish with this insulated binding post terminal cup. The binding posts will accept up to 10 gauge wire and use standard 3/4" spacing to accept dual banana plugs. Includes gasket.
  • Standard 0.75" spacing on binding posts to accepts most dual bananna plugs
  • Includes rear gasket for a good seal to enclosures
  • Outside dimensions: 3.6" W x 3" H (cutout: 2.35" W x 1.75" H)
  • Rear terminals accept standard 0.205" female disconnect
BUYOUT $3.05
711 In Stock
We'll send you an email when 3-5/8" x 3-1/8" Rectangular Banana Jack Terminal Cup is back in stock or available for preorder.
This rectangular terminal cup features insulated binding posts, minimizing the risk of accidental shorts, with standard 3/4" spacing to allow the use of most dual banana plugs. The binding posts will accept up to 10 gauge bare wire for high power use. The back side has standard solder tabs that will also accept 0.205" female disconnects for easy connections. The cup also includes a gasket to ensure an air tight seal to your enclosure.
Special purchase -- limited quantities available!
Dimensions: • Overall size: 3-5/8" W x 3-1/8" H; Cutout: 2-3/8" W x 1-3/4" H • Connectors accept 0.205" female disconnect terminals • Includes gasket.
BrandFactory Buyouts
Part Number269-2114
UPC848864026275
Weight0.1
