  • 3-1/2" 10W Mylar Surface Mount Speaker Ivory
BUYOUT 3-1/2" 10W Mylar Surface Mount Speaker Ivory
Factory BuyoutsPart # 299-2250
This surface mount speaker is ideal for reproducing frequencies in the vocal range making it suitable for paging, intercom, and security purposes. The efficient 3" driver uses a poly cone and surround making it acceptable for use in damp locations.
  • Compact size can mount almost anywhere
  • Ideal for commercial or educational applications
  • 4 inch speaker leads for simple connections
  • Poly cone and surround for use in damp locations
BUYOUT $1.90
369 In Stock
We'll send you an email when 3-1/2" 10W Mylar Surface Mount Speaker Ivory is back in stock or available for preorder.
Sometimes when we make a surplus buy little gems come rolling out of the boxes, and frankly speaking, this is not one of them. The ivory color is a throwback to the 70's or 80's, one of those decades for sure, so it might be perfectly suited for a retro looking application. The design of the enclosure certainly won't turn any heads. It's square, with grill holes in the front….but it does the job.
The speaker can be surface mounted using the back plate, which is easy to remove, and using the 4 holes found on it you can mount it anywhere--out of site might just be perfect location. The 4 inch long speaker wire makes connections a snap. Buy 1 or 100 today.
Specifications: • Power Handling: 10 watts • Dimensions: 2" D x 4" H x 4" W
BrandFactory Buyouts
Part Number299-2250
UPC848864027708
Weight0.95
