  • Belden Snap-N-Seal ProSNS F-type RG-6 Compression Connector 25 Pack
CLEARANCE Belden Snap-N-Seal ProSNS F-type RG-6 Compression Connector 25 Pack
BeldenPart # 092-766
Model: FSNS6U
When your time, money, and reputation depend on terminating coaxial cable quickly and reliably, count on Belden Snap-N-Seal ProSNS.
  • F-type compression connector fits industry standard RG-6 and quad shield RG-6 coaxial cable
  • Integrated O-ring locks out moisture
  • Floating-pin insertion guide for easier installation
We'll send you an email when Belden Snap-N-Seal ProSNS F-type RG-6 Compression Connector 25 Pack is back in stock or available for preorder.
This connector is an excellent choice for F-type termination of both RG-6 and quad shield RG-6 cable.
When Belden acquired the manufacturers of both Snap-N-Seal and F-Conn, the company didn't rest on its laurels. Engineers took technology from both lines to create the best compression connectors in the world: Snap-N-Seal ProSNS.
By providing true 360° compression, these connectors are have superior RF shielding, rated at an effective -85 dB. All three connector styles, F-type, RCA, and BNC, feature 75 ohm impedance for low signal loss. The floating pin insertion guide, low insertion force, low compression force, and innovative sealing O-ring all help to create a connector that's easy to use, reliable, and can be installed using nearly any standard compression tool.
Specifications: • Base metal: Brass • Contact plating: Nickel-tin alloy • Sold per: 25 pack • Entry hole 7 mm • Termination style: Compression • Dimensions: 0.44" x 1.25" (uncompressed).
BrandBelden
ModelFSNS6U
Part Number092-766
UPC845671004847
Unit of MeasurePackages
Weight0.55
F Male TypeCompression
Fits CableRG-6 & RG-6 Quad Shield
