  • Belden Snap-N-Seal ProSNS BNC RG-59 Security Compression Connector 25 Pack
CLEARANCE Belden Snap-N-Seal ProSNS BNC RG-59 Security Compression Connector 25 Pack
BeldenPart # 092-774
Model: FSNS59BNCSL
When your time, money, and reputation depend on terminating coaxial cable quickly and reliably, count on Belden Snap-N-Seal ProSNS.
  • BNC male compression connector fits RG-59 security coaxial cable
  • Integrated O-ring locks out moisture
  • Floating-pin insertion guide for easier installation
We'll send you an email when Belden Snap-N-Seal ProSNS BNC RG-59 Security Compression Connector 25 Pack is back in stock or available for preorder.
This connector is an excellent choice for BNC male termination of RG-59 security cable. Security cable is usually constructed with a copper center conductor and braid with no inner foil, varying in diameter from different manufacturers and making installation difficult. The split ferrule in this connector collapses on the cable jacket when the sleeve is compressed, accommodating a wide number of RG-59 security cable variations.
When Belden acquired the manufacturers of both Snap-N-Seal and F-Conn, the company didn't rest on its laurels. Engineers took technology from both lines to create the best compression connectors in the world: Snap-N-Seal ProSNS.
By providing true 360° compression, these connectors are have superior RF shielding, rated at an effective -85 dB. All three connector styles, F-type, RCA, and BNC, feature 75 ohm impedance for low signal loss. The floating pin insertion guide, low insertion force, low compression force, and innovative sealing O-ring all help to create a connector that's easy to use, reliable, and can be installed using nearly any standard compression tool.
Specifications: • Base metal: Brass • Contact plating: Nickel-tin alloy • Sold per: 25 pack • Entry hole 6 mm • Termination style: Compression • Dimensions: 0.56" x 1.69" (uncompressed).
BrandBelden
ModelFSNS59BNCSL
Part Number092-774
UPC845671004601
Unit of MeasurePackages
Weight0.9
GenderMale
Mounting TypeCable Mount
