  • 2.5mm x 5.5mm x 9.5mm DC Barrel Power Plug
Parts ExpressPart # 090-5004
This DC coaxial power plug, with solder terminals, replaces damaged plugs on AC or DC adapters. Shorter 9.5 mm tip will fit tighter in shallow DC coaxial jacks.
  • 2.5 mm x 5.5 mm x 14 mm tip dimensions
  • Screw-on housing for easy access
  • Solder terminals for a solid connection
  • Metal crimp internal and plastic external strain relief
Your Price: $1.19
MSRP: $1.99
Save $0.80 (40%)
493 In Stock
We'll send you an email when 2.5mm x 5.5mm x 9.5mm DC Barrel Power Plug is back in stock or available for preorder.
Order in the next 15 hr 45 min to ship today. Details
Don't take a chance on frayed wires or power adapters plugs that kick on-and-off when you move them. This could permanently damage your equipment or power adapter. Save money by changing the adapter tip before it's too late. This coaxial power plug can replace the tip on old adapters which have the wrong size plug, but have the right voltage and current rating.
Part Number090-5004
UPC848864024240
Weight0.006
DC Power Connector TypePlug
