  • Parts Express 2.5mm 4C Right Angle Barrel Power Plug with 12" Cable
CLEARANCE Parts Express 2.5mm 4C Right Angle Barrel Power Plug with 12" Cable
Parts ExpressPart # 090-504
This is the hard to find 2.5 mm 4 conductor plug used on cell phones. Use this plug to custom build cell phone adaptors. A right angle male plug allows for close proximity placement without worrying about the damage associated with large cumbersome adapters.
  • Create your own cell phone or camcorder accessories
  • 12" four conductor cable included
  • Nickel plated right angle 2.5 mm plug with tip, ring, ring, sleeve configuration
CLEARANCE $0.46
Save $6.53 (93%)
341 In Stock
We'll send you an email when Parts Express 2.5mm 4C Right Angle Barrel Power Plug with 12" Cable is back in stock or available for preorder.
This is the hard to find 2.5 mm 4 conductor plug used on cell phones. Use this plug to custom build cell phone adaptors to use standard headphones. A right angle male plug allows for close proximity placement without worrying about the damage associated with large cumbersome adapters. The twisted pair conductors are pre-stripped for quick connection, while the tinned, overall shield acts as the fourth conductor for ground. Common cell phone configuration: Tip = Microphone (NOT connected), 1st Ring = Right Speaker +, 2nd Ring = Left Speaker +, Base = Common Ground -. Right angle plug with 12" pigtail.
• Note: In order to reduce the chance for noise, there is no conductor connected to the tip of the 2.5 mm plug (microphone positive). The specification sheet is shown for informational purposes only. Microphone conductor (shown in specification sheet) is not present on product.
Part Number090-504
UPC844632068409
Weight0.08
ConductorsStereo TRS
GenderMale / Plug
Mounting TypeCable Mount
