  • 2.1mm Panel Mount DC Barrel Power Jack
Parts ExpressPart # 090-5012
Popular dimension power jacks for projects and repair.
  • Common 2.1 x 5.5 mm internal dimensions
  • Built-in N.C. switch that disconnects the extra terminal to prevent charging alkaline and other non-rechargeable batteries
Your Price: $1.98
Save $2.01 (50%)
We'll send you an email when 2.1mm Panel Mount DC Barrel Power Jack is back in stock or available for preorder.
Estimated back in stock 11/6/2026
You can use this common DC jack for projects and internal repairs. Can be assembled tip positive or tip negative for DC applications. Works equally well for AC applications. The terminal connected to the center rivet is tip and the closest terminal to it is barrel. This jack has a normally closed switch built-in that disconnects the barrel to prevent charging alkaline and other non-rechargeable batteries in a portable project. That's what the extra terminal is for.
Specifications: • Dimensions with terminals: 0.9" H x 0.43" D • Mounting Diameter: 0.31" • Current capacity: 3 amps.
Part Number090-5012
UPC848864024288
Weight0.009
DC Power Connector TypeJack
