  • 2 x 50W High-Power Bluetooth 5.0 Amplifier Board with On/Off Volume Switch
Parts ExpressPart # 320-6051
Looking to boost the sound output from your next small DIY wireless audio project? Look no further than our 2 x 50W Max Bluetooth 5.0 amplifier board! Designed for convenience and performance, this compact amplifier board is the perfect addition to any audio setup.
  • Wide 5 VDC to 24 VDC working voltage (12 to 24 VDC for best performance)
  • Efficient Class D CS8673E amp chip and wireless 5.0 Bluetooth in one compact size board
  • Built-in on/off volume control for convenience
  • Standard 2.1 x 5.5 mm DC jack power input jack
  • Includes volume knob and 2.1 x 5.5 mm 8" pig tail plug when mounted in an enclosure
  • Pre-assembled and pre-tested for easy project integration
  • Simple quiet tone when it turns on and searches for Bluetooth device
Your Price: $9.98
Save $10.01 (50%)
We'll send you an email when 2 x 50W High-Power Bluetooth 5.0 Amplifier Board with On/Off Volume Switch is back in stock or available for preorder.
One of the standout features of this amplifier board is its mini size, making it incredibly versatile and easy to incorporate into your project. Whether you're building your own speakers, a portable sound system, or simply looking to enhance your existing audio setup, this amplifier board is the ideal choice. Its compact size allows you to save space without compromising on performance.
With Bluetooth 5.0 technology, you can now connect your devices wirelessly, enabling a seamless and hassle-free listening experience. Stream music directly from your smartphone, tablet, or any other Bluetooth-enabled device, and enjoy high-quality audio without the need for messy cables.
In addition, the on/off switch volume control adds another layer of convenience. You can easily adjust the volume levels directly on the amplifier board, giving you complete control over your audio experience. No more fumbling around with separate volume controls or searching for the remote – it's all at your fingertips.
But what about the sound quality? Rest assured, our 2 x 50W Max Bluetooth 5.0 amplifier board delivers impressive power and clarity. With a maximum output power of 50W per channel, you can crank up the volume and enjoy room-filling sound. Whether you're a music lover, audiophile, or home theater enthusiast, this amplifier board will surely take your audio experience to the next level.
What's more, this Bluetooth amplifier board is designed for easy installation, making it an ideal choice for both beginners and experienced DIYers. Simply connect your speakers, power it up, and you're ready to go. It's a quick and straightforward build that requires minimal technical knowledge.
So, why wait? Dive into your next DIY audio project and upgrade your sound system with our 2 x 50W Max Bluetooth 5.0 amplifier board. Get ready to experience a whole new level of audio quality and enjoy your favorite tunes like never before. Unleash the power of music with this compact, versatile, and easy-to-use amplifier board.
Note: Blue light flashes when searching to pair with a Bluetooth device. Switches to solid when paired.
Specifications: • Power output: 2 x 50 watts @ 4 ohms 24 VDC • Voltage input: 5 to 24 VDC • Speaker impedance: 4 to 8 ohms • Bluetooth version: 5.0 • Bluetooth name: ZK-502L • Board size: 2-3/16" x 1-1/2" x 9/16" (55 x 38 x 15 mm).
Part Number320-6051
UPC848864074924
Weight0.1
Board Type2 Channel Stereo Amp
Power (RMS/Channel 8 ohms)0 - 25 Watts
Special FeaturesBluetooth Wireless
