  • 2 x 30W Outdoor Bluetooth 5.0 Amplifier Kit with AC Cord, Landscape Speakers, 100 ft. Speaker Wire
Parts ExpressPart # 300-7358
Looking to enhance your outdoor gatherings with some lively tunes? Look no further than our outdoor amplifier speaker kit, designed to bring you Bluetooth wireless music outside the house. Whether you're lounging by the pool, relaxing on the patio, or enjoying the beauty of your landscape, this kit is the perfect addition to your outdoor entertainment setup.
  • All the components are designed to withstand outdoor environments for long lasting performance
  • Builds quickly without any soldering required
  • 6.5" woofer with a coaxial 1" tweeter providing a balanced, natural response
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
Add Music to Your Outdoor Setting
Elevate your outdoor entertainment with our Bluetooth outdoor amplifier kit with waterproof speakers. Whether you're hosting a barbecue, throwing a pool party, or simply enjoying a relaxing evening outdoors, this kit will bring a new level of excitement to your outdoor space. Just hook up the speakers, plug it in, connect via Bluetooth, and let the music set the mood. It's that simple. No need to drill holes through your wall to an indoor amplifier.
Bluetooth and Waterproof Team Together
The versatility of the waterproof amplifier kit enables you to easily blend it into your outdoor space. Whether you choose to attach it to an outdoor AC socket or wire it directly into an outdoor light box, the installation process is quick and hassle-free. Building the kit requires no soldering and the burial outdoor cable installs into the speakers with a small screwdriver once the wire is stripped. All that's left is mounting the speakers and amp kit. You can start enjoying your favorite music in no time.
One of the greatest features of this kit is its ability to connect via Bluetooth. Simply pair your smartphone or tablet to any Bluetooth-enabled device with the amplifier and let the music flow. No more worrying about messy wires or tangled cords. Now you can control your playlist from the convenience of your phone or tablet during a poolside party while lounging on the deck.
Total Protection From the Weather
Not only does our kit deliver superb audio, but it is also designed to withstand the elements. Protecting the waterproof internal components is a waterproof, UV resistant utility box. Built with durable materials, it handles various weather conditions adding extra protection for long lasting audio performance. The speakers are made to withstand the harshest weather and the outdoor speaker wire even withstands burial conditions. That means you can enjoy your favorite tunes outside without worrying about rain or shine.
Crank it UP
Powering the outdoor kit is the waterproof 2 x 50W Lepai LWP-250 Bluetooth 5.0 amplifier. It delivers full, high quality, clean stereo sound that'll cover a large patio or picnic shelter when paired with these Dayton Audio 6-1/2" 2-way waterproof outdoor landscape speakers. OFC 14 gauge outdoor speaker wire helps prevent signal loss during long runs and the water resistant tape keeps moister away from the internal conductors insuring continuous high performance.
Simplest Way to Have Outdoor Music
So, why wait and pay for an outdoor contractor when you can do it yourself. Check the tools needed and instructions in our online builders guide to see how simple it is. It's time to add music to your next outdoor event, or just relaxing outside next to the pool or fire pit.
Note: The switch on the back of the speakers must be set to 8 ohms. Use silicon sealer to cover the exposed speaker wires all the way to the wire jacket to extend the connection life and to help prevent moister from seeping under the jacket.
Specifications: • Amplifier power output: 50 watts x 2 @ 6 ohms 24 VDC • Frequency response: 20 Hz-20,000 kHz +/- 3% • Conversion efficiency: >82% • Impedance: 4-8 ohms • Amplifier input voltage: 12-24 VDC, 12 VAC • Amplifier input amperage: 4A • Amplifier topology: Class D • Bluetooth range: Up to 50 feet • Bluetooth 5.0 • Bluetooth name: Lepai LWP-250 • Dimensions with mounting flanges: 4.33" W x 1.9" D x 1" H (110 x 48 x 25 mm)• Mounting screw spacing manual correction: 4.05" and 1.42" (103 x 36 mm) to center • Power supply input voltage: 100~240 VAC 50/60 Hz 1.2A Max • Power supply output voltage: 12 VDC 5.0A.
Part Number300-7358
UPC848864075990
Weight28.91
