Quickly create a 12 VDC Hi-Fi stereo audio amplifier with headphone output with this kit featuring the Yamaha YDA138-E amp chip. It delivers quality sound to most bookshelf speakers and has all the jacks ready to accept all external components without any soldering. Drill a few precise holes in the included project box and your ready to go. Control the volume with the built-in potentiometer or plug your smartphone into the Aux-in jack and use an App to control volume and tone. The only tool you need to finish is a small screw driver to tighten the screws in the case and speaker wire jack. Plug the included 12 VDC 2A AC adapter into the 2.1 x 5.5mm tip positive power jack, add speakers, and a audio source then crank it up. Use the attached drawing to cut your holes
There's still one more option that most small amplifiers don't have. A 3.5mm stereo headphone jack the kicks out the speaker output for private listening. Pull out your best headphones and hook up your favorite audio component player, or use it as a headphone amplifier for multiple headphones.
Specifications: • Power output: 10.98W x 2 RMS @ 4 ohms with 12 VDC • Frequency response: 20-20 kHz • THD+N @ rated power: 2.5% • SNR, A-weighted: 97.6 dB • Channel crosstalk: 43 dB • Max input sensitivity voltage: 230 mV • Headphone jack: 50mW • Board dimensions: 2.6" W x 4" D x 0.75" H without added jacks and controls • Project dimensions without the knobs or switch: 4.13" x 4.33" x 1.38"
