  • 18650 Dual Battery Holder with Leads
Parts ExpressPart # 140-781
This two 18650 battery holder enables the use of a long lasting, incredible stand by time, 3.7 volt Li-Ion battery for your next 12 VDC project.
  • 6" leads with tinned ends ready to solder
  • Two counter sunk 3 mm screw holes for mounting
  • Holds two 18650 flat top and button top Li-Ion batteries up to 2.7" L x 0.73" W
Your Price: $2.98
MSRP: $5.99
Save $3.01 (50%)
We'll send you an email when 18650 Dual Battery Holder with Leads is back in stock or available for preorder.
Estimated back in stock 5/15/2026
Use this 18650 battery holder for your next portable electronic project that requires 12 VDC. Li-Ion batteries deliver a long lasting play and standby time. The 26 AWG 6" tinned leads solder easily into a PC board or power jack. Two 3 mm counter sunk screw holes are available for optional flathead screws to securely mount the holder inside your project. Dimensions 1.53" W x 2.97" H x 0.79" D enable the holder to fit into small projects.
Part Number140-781
UPC848864053264
Size18650
