  • Lishen 18650 3350mAh Li-Ion Flat Top Battery 3-Pack
CLEARANCE Lishen 18650 3350mAh Li-Ion Flat Top Battery 3-Pack
LishenPart # 142-108
This economical 3-pack of 18650 Li-Ion batteries combined together will run many low power amp boards and other 12 VDC projects. They work great by themselves in flashlights and other 3.7 VDC devices.
  • Economical 3-pack saves money
  • 3350mAh for long lasting power
  • Long standby time between charges
  • Includes protective storage case
  • Polarity marked on the battery for safety
CLEARANCE $14.98
MSRP: $29.98
Save $15.00 (50%)
516 In Stock
We'll send you an email when Lishen 18650 3350mAh Li-Ion Flat Top Battery 3-Pack is back in stock or available for preorder.
18650 batteries fit many different applications and continue to be a fast growing size of Li-Ion battery. Dayton Audio's KAB-BE and LBB-3v2 battery extension boards use three 18650 batteries to power the KAB Bluetooth and other 12 VDC amp boards for long lasting music. Buy two packs batteries for Dayton Audio's LBB-6S battery board. Many LED flashlights use 18650 batteries for a brighter, long lasting beam that can be recharged over-and-over.
Li-Ion batteries work better than other types of rechargeable batteries, because they have a longer standby time. Flashlights sit for months before they're used, in some cases, and when you go to use it, after a couple of months off the charger, the batteries are dead. Li-Ion batteries keep 90% of their charge for six months and are also lighter than other rechargeable batteries that have the same current rating and voltage. The next time you need to buy a flashlight or build a new project make sure long lasting 18650 Li-Ion batteries are its power source.
Specifications: • Voltage: 3.7 VDC • Current rating: 3350mAh • Dimensions: 2.56" L x 0.72" Dia. (65 x 18.25 mm).
BrandLishen
Part Number142-108
UPC848864070537
Weight0.4
Size18650
TechnologyLi-Ion
Voltage3.7V
