  • 14 AWG 6ft Professional Grade Braided Speaker Cable Wire with Gold Plated Banana Jacks
CLEARANCE 14 AWG 6ft Professional Grade Braided Speaker Cable Wire with Gold Plated Banana Jacks
Parts ExpressPart # 189-700
Quickly connect together speakers and an amplifier, with binding post, using this professional grade, 14 AWG, durable, oxygen-free stranded speaker wire with gold plated banana plugs.
  • Rope layer stranded OFC 14 AWG speaker wire prevents signal loss
  • Gold plated banana jacks for best electrical contact
  • Braided polypropylene outer jacket for maximum protection and tangle-free handling
  • Cable pants, heat shrink, and set screws ensure long lasting connection and durability
  • Clothe filler inside the outer black PVC jacket for flexibility
  • Secure a quick connection from your speakers to your amplifier or receiver without having to twist, tighten, or poke into a hole stripped speaker wire
We'll send you an email when 14 AWG 6ft Professional Grade Braided Speaker Cable Wire with Gold Plated Banana Jacks is back in stock or available for preorder.
Audtek banana plug 14 AWG speaker cable’s design delivers the ultimate in high quality performance. Each conductor has 16 layers of 7/34 gauge OFC strands twisted around each other to keep the signal constant all the way to your speakers. The gold-plated banana plugs ensure a consistent electrical connection and their set screws combined with heat shrink secure the wire inside the plugs. The polypropylene weave prevents accidental damage to the cable’s black PVC outer jacket while the cable pants protect the black and red inner conductor’s PVC insulators that spit into each individual banana plug.
Why fool around unscrewing binding post, striping wire, twisting the strands together and retightening binding post when plugging in Audtek’s speaker cable with four banana plugs is so much easier. Some dual binding posts are so close together it’s hard to get your fingers around the cap to unscrew them. Other binding posts are missing a hole in the shaft to stick the bare speaker wire through, so you have to wrap the wire around the shaft. As soon as you try to tighten the cap down on the bare wire it wants to slip out. Using Audtek banana plug speaker cable prevents this aggravation, while insuring a high-quality connection every time.
Note: Cables sold individually which enables you to buy the amount of speaker cables you need to match your system.
Part Number189-700
UPC848864075143
Weight0.45
Cable Length6feet
Cable TypeBanana to Banana
Jacket ColorBlack
Wire Gauge14
