  • 12V 1A DC Switching Power Supply AC Adapter with 2.1 x 5.5mm Tip (+) Plug and 5 ft. Cord
CLEARANCE 12V 1A DC Switching Power Supply AC Adapter with 2.1 x 5.5mm Tip (+) Plug and 5 ft. Cord
Parts ExpressPart # 120-1201
This regulated 12 VDC 1A switching power supply is ideal for replacing lost or damaged power supplies from your electronic devices or as a foundation for new projects.
  • Efficient and reliable switching power supply
  • UL listed and RoHS for safety
  • Level VI standby certified
  • Common 2.1 mm x 5.5 mm center positive plug
We'll send you an email when 12V 1A DC Switching Power Supply AC Adapter with 2.1 x 5.5mm Tip (+) Plug and 5 ft. Cord is back in stock or available for preorder.
Switching power supplies are reliable, compact, and efficient. This regulated 12 volt DC power supply provides ample current to run many popular 12V devices. Use it to replace a lost or damaged power supply for AV equipment, office devices, battery chargers, and other electronic components that draw less than 1A. UL listed and RoHS compliant.
Specifications: • Power output: 12 VDC 1A • Power input: 100~240 VAC, 50/60 Hz, 0.5A • Output connector: 2.1 mm x 5.5 mm x 9.5 mm, center positive • Cable length: 4.92 ft. (1.5m) • Adapter dimensions: 1.13" W x 2.69" H x 1.59" D (28.5 x 68.35 x 40 mm) without AC prongs.
Part Number120-1201
UPC848864069159
Weight0.2
Center/Tip PolarityCenter Positive
Current Capacity1000mA
DC Output Voltage12V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
