  • 1208PO38A 3" x 5" 5W Paper Cone Speaker 8 Ohm
BUYOUT 1208PO38A 3" x 5" 5W Paper Cone Speaker 8 Ohm
Factory Buyouts
Part #299-4334
Factory Buyouts
Part #299-4334
Model: 1208PO38A
The 1208PO38A 3" x 5" Speaker uses a paper cone and cloth surround to produce natural full-range response from 150 to 15,000 Hz. Thanks to the powerful shielded motor this driver has excellent efficiency for its size.
  • Shielded magnet assembly is suitable for use near sensitive electronics
  • Flat mounting flange for simple front or rear mount installation
  • Perfect for use in slim designs such as sound bars and portable speakers
BUYOUT $2.88
Quantity:Qty: 1-29 $2.88/ea
Quantity:Qty: 30-59 $2.56/ea
Quantity:Qty: 60+$2.45/ea
Order in the next 0 hr 52 min to ship today. Details
744In Stock
The 1208PO38A 3" x 5" Speaker has a 5" x 3" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. This driver can produce an impressive amount of output for its size making it perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandFactory Buyouts
Model1208PO38A
Part Number299-4334
UPC848864074108
Weight0.55
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Frequency Response150 to 10,000Hz
Sensitivity85.07dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)145.2Hz
DC Resistance (Re)7.279Ω
Voice Coil Inductance (Le)0.1679mH
Mechanical Q (Qms)6.594
Electromagnetic Q (Qes)2.094
Total Q (Qts)1.589
Compliance Equivalent Volume (Vas)0.05ft³
Diaphragm Mass Inc. Airload (Mms)1.886g
Surface Area of Cone (Sd)40.72cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Depth2"
