  • 1208PB-088A 3" x 5" 5W Paper Cone Speaker 8 Ohm
BUYOUT 1208PB-088A 3" x 5" 5W Paper Cone Speaker 8 Ohm
Factory Buyouts
Part #299-4172
Factory Buyouts
Part #299-4172
Model: 1208PB088A
The 1208PB-088A 3" x 5" Speaker uses a paper cone and cloth surround to produce natural full-range response from 150 to 15,000 Hz. Thanks to the powerful shielded motor this driver has excellent efficiency for its size.
  • Shielded magnet assembly is suitable for use near sensitive electronics
  • Perfect for use in slim designs such as sound bars and portable speakers
  • Flat mounting flange for simple front or rear mount installation
BUYOUT $2.88
Quantity:Qty: 1-29 $2.88/ea
Quantity:Qty: 30-59 $2.56/ea
Quantity:Qty: 60+$2.45/ea
Order in the next 4 hr 11 min to ship today. Details
894In Stock
The 1208PB-088A 3" x 5" Speaker has a 5" x 3" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. This driver can produce an impressive amount of output for its size making it perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandFactory Buyouts
Model1208PB088A
Part Number299-4172
UPC848864073330
Weight0.35
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Frequency Response150 - 15,000Hz
Sensitivity81.58dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)152Hz
DC Resistance (Re)7.712Ω
Voice Coil Inductance (Le)0.203mH
Mechanical Q (Qms)5.325
Electromagnetic Q (Qes)4.869
Total Q (Qts)2.543
Compliance Equivalent Volume (Vas)0.045ft³
Diaphragm Mass Inc. Airload (Mms)1.981g
Surface Area of Cone (Sd)40.72cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Depth1.75"
