  • 1208PB-088A 3" x 5" 5W Paper Cone Speaker 8 Ohm
BUYOUT 1208PB-088A 3" x 5" 5W Paper Cone Speaker 8 Ohm
Factory BuyoutsPart # 299-4222
Model: 1208PB-088A
The 1208PB-088A 3" x 5" 5W Paper Cone Speaker uses a paper cone and cloth surround to produce natural full-range response from 150 to 15,000 Hz. Thanks to the powerful shielded motor this driver has excellent efficiency for its size.
  • Shielded magnet assembly is suitable for use near sensitive electronics
  • Flat mounting flange for simple front or rear mount installation
  • Perfect for use in slim designs such as sound bars and portable speakers
BUYOUT $1.44
MSRP: $2.88
Save $1.44 (50%)
493 In Stock
We'll send you an email when 1208PB-088A 3" x 5" 5W Paper Cone Speaker 8 Ohm is back in stock or available for preorder.
The 1208PB-088A 3" x 5" 5W Paper Cone Speaker has a 5" x 3" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. This driver can produce an impressive amount of output for its size making it perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandCoast Buyouts
Model1208PB-088A
Part Number299-4222
Weight0.35
Power Handling (RMS)5 Watts
Power Handling (MAX)10 Watts
Frequency Response150 to 10,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)145.2Hz
DC Resistance (Re)7.279Ω
Voice Coil Inductance (Le)0.1679mH
Mechanical Q (Qms)6.594
Electromagnetic Q (Qes)2.094
Total Q (Qts)1.589
Compliance Equivalent Volume (Vas)0.039ft³
Diaphragm Mass Inc. Airload (Mms)2.414g
Surface Area of Cone (Sd)40.72cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Overall Outside Diameter3.125 x 4.875"
Depth1.625"
