  • 120319BF 1" x 3-1/8" Paper Cone Speaker 6 Ohm
CLEARANCE 120319BF 1" x 3-1/8" Paper Cone Speaker 6 Ohm
Factory BuyoutsPart # 289-2290
Model: 120319BF
The 120319BF driver is a rectangular driver that has a wide frequency range of 200 to 15,000 Hz. The short height of this driver makes it optimal for situations where surface space is limited such as models and DIY projects.
  • Rubber surround and motor design allow this driver to have great low-frequency extension for its size
  • The flange design makes this driver ideal for unique projects involving limited space
  • 6 Ohm impedance mates well to most small amplifiers
We'll send you an email when 120319BF 1" x 3-1/8" Paper Cone Speaker 6 Ohm is back in stock or available for preorder.
The 120319BF is a rectangular full-range driver that has a frequency range of 320 to 15,000 Hz. The unique flange on this driver allows this driver to be optimal for situations where surface space is limited such as models and DIY projects.
BrandFactory Buyouts
Model120319BF
Part Number289-2290
UPC848864048673
Weight0.1
Nominal Diameter1 x 5"
Power Handling (RMS)10 Watts
Power Handling (MAX)15 Watts
Impedance6Ω
Frequency Response200 to 15,000Hz
Sensitivity75.1dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)260Hz
DC Resistance (Re)5.54Ω
Voice Coil Inductance (Le)0.266mH
Mechanical Q (Qms)4.21
Electromagnetic Q (Qes)7.27
Total Q (Qts)2.66
Compliance Equivalent Volume (Vas)0.0021ft³
BL Product (BL)1.059T·m
Surface Area of Cone (Sd)10.17cm²
Cone MaterialPaper
Voice Coil FormerPaper
Overall Outside Diameter1 x 3.155"
Baffle Cutout Diameter0.78 x 2.91"
Depth1.12"
