  • 12V 6A Switching Grounded DC Power Supply AC Adapter with 2.5 x 5.5mm Center Positive (+) Plug
Parts ExpressPart # 120-079
This grounded regulated 12 VDC 6A power supply is ideal for replacing lost or damaged power supplies from your electronic devices or as a foundation for LED light strips, 12 VDCamplifiers, and other new 12 VDCprojects.
  • Efficient and reliable switching power supply
  • 12V regulated DC output at 6 amps for current hungry electronics
  • Common 2.5 mm x 5.5 mm x 9 mm center positive plug
  • Certified level VI standby current
  • Includes 4 ft. 3-prong IEC detachable AC cord for versatility
  • FCC, CE certified and UL listed for safety
Your Price: $17.98
Save $15.01 (45%)
5 In Stock
We'll send you an email when 12V 6A Switching Grounded DC Power Supply AC Adapter with 2.5 x 5.5mm Center Positive (+) Plug is back in stock or available for preorder.
Switching power supplies are reliable, compact, and efficient. This regulated 12 volt DC power supply provides ample current to run many popular 12 VDC devices. Use it to replace a lost or damaged power supply for A/V equipment, office devices, battery chargers, and other electronic components. Detachable 4 ft. AC input cord with 4ft. attached DC cord enables you to attach an optional longer IEC, or European IEC AC cord (sold separately).
Specifications: • Input voltage: 100~240 VAC, 50/60 Hz @ 2A Max • Output voltage: 12 VDC 6A • Output connector: 2.5 mm x 5.5 mm x 9 mm, center positive • Dimensions: 5-1/2" L x 2-1/2" W x 1-1/2" D (139 x 63 x 38 mm).
Part Number120-079
UPC848864047126
Weight1.05
Center/Tip PolarityCenter Positive
Current Capacity6000mA
DC Output Voltage12V
Input Voltage100~240 VAC
Plug Size2.5 x 5.5 mm
