  • 12V 3.5A Power Supply with Cigarette Lighter Style Accessory Socket Port
CLEARANCE 12V 3.5A Power Supply with Cigarette Lighter Style Accessory Socket Port
Parts ExpressPart # 120-053
This power adapter enables you to power devices, with less than 3.5A current draw, that have a vehicle 12 VDC power accessory/cigarette lighter plug into AC current in the house or motel.
  • 3.5 amps of output current for power hungry electronics
  • No cord--plugs directly into wall outlet
  • 90 degree foldable AC pin makes it very compact
  • ETL approved for safety
  • Input 100-240 VAC 50/60 Hz for international use
  • Meets U.S. level VI efficiency requirements
CLEARANCE $8.10
Save $29.89 (79%)
160 In Stock
We'll send you an email when 12V 3.5A Power Supply with Cigarette Lighter Style Accessory Socket Port is back in stock or available for preorder.
Order in the next 14 hr 34 min to ship today. Details
This adapter works great for devices that would normally only work in your vehicles cigarette lighter/accessory socket. Air pumps, small electronic coolers, and other products that only come with an accessory/cigarette lighter plug will fit right into the socket of this AC adapter. It will keep these devices, requiring less than 3.5A, running while you sleep in your home or travel lodging. This AC adapter also replaces a cellphone house charger as long as you still have a cellphone car charger.
Specifications:• Input voltage: 100 - 240 VAC @ 50/60 Hz • Output voltage: 13.8V @ 3.5A • Dimensions: 2-3/8" W x 3-9/16" H x 1-2/3" D.
Part Number120-053
UPC848864046327
Weight0.4
Center/Tip PolarityCenter Positive
Current Capacity3500mA
DC Output Voltage12V-13.8V
Input Voltage100~240 VAC
Plug Size12V Accessory Outlet
