  • Sharp 1004PB32WA 1-3/4" x 4" Paper Cone Shielded Full-Range Speaker 16 Ohms
BUYOUT Sharp 1004PB32WA 1-3/4" x 4" Paper Cone Shielded Full-Range Speaker 16 Ohms
Factory BuyoutsPart # 299-4220
Model: 1004PB32WA
The Sharp 1004PB32WA 1-3/4" x 4" paper cone shielded full-range speaker uses a paper cone and cloth surround to produce natural full-range response from 150 to 14,000 Hz. The 16 ohm impedance makes this driver perfect for wiring multiples in parallel to increase power handling and overall output capability.
  • Common size used in many popular TV's
  • Naturally damped paper cone delivers smooth response
  • Shielded magnet allows use near sensitive electronic equipment
  • Treated cloth surround offers many years of reliable performance
BUYOUT $1.44
MSRP: $2.88
Save $1.44 (50%)
1352 In Stock
We'll send you an email when Sharp 1004PB32WA 1-3/4" x 4" Paper Cone Shielded Full-Range Speaker 16 Ohms is back in stock or available for preorder.
The Sharp 1004PB32WA 1-3/4" x 4" paper cone shielded full-range driver has a 4-3/4" x 1-3/4" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. The high aspect ratio and shielded magnet makes this speaker perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandCoast Buyouts
Model1004PB32WA
Part Number299-4220
UPC848864073576
Weight0.3
Nominal Diameter2-1/2 x 4"
Bolt Circle Diameter4.5
Power Handling (RMS)6 Watts
Power Handling (MAX)12 Watts
Impedance16Ω
Frequency Response150 to 14,000Hz
Sensitivity77dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)224Hz
DC Resistance (Re)15.1Ω
Voice Coil Inductance (Le)0.1mH
Mechanical Q (Qms)3.54
Electromagnetic Q (Qes)5.26
Total Q (Qts)2.12
Compliance Equivalent Volume (Vas)0.01ft³
Mechanical Compliance of Suspension (Cms)0.065mm/N
BL Product (BL)2.35T·m
Diaphragm Mass Inc. Airload (Mms)1.37g
Maximum Linear Excursion (Xmax)1.25mm
Surface Area of Cone (Sd)23.3cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerPaper
Overall Outside Diameter1.75" x 4.75"
Baffle Cutout Diameter1.5" x 3.75""
Depth1.625"
# Mounting Holes6
Sealed Volume0.03ft³
Sealed F3176Hz
