  • 1/4" Stereo Phone Plug Metal
Parts ExpressPart # 090-307
This 1/4" 3-conductor phone plug is a capable, all-metal solution for terminating 1/4" unbalanced signal cables and headphone cables.
  • Rugged all-metal construction
  • Accepts up to 6 mm O.D. wire
  • Spring-type strain relief
Your Price: $1.79
Save $1.20 (40%)
218 In Stock
We'll send you an email when 1/4" Stereo Phone Plug Metal is back in stock or available for preorder.
The next time you terminate a 1/4" balanced signal cable, try this economical contender. The all-metal body stands up to professional use, while the spring-type strain relief "tail" of this connector helps insure that they wire you choose will stay with the connector.
Specifications: • Contact plating: nickel • Sold per: each • Finish: nickel • Termination style: solder • Entry hole: 6 mm • Dimensions: 0.5" x 3.25".
Part Number090-307
UPC844632010576
Weight0.0462
ConductorsStereo TRS
GenderMale / Plug
Mounting TypeCable Mount
