  • 1/4" Mono Big Fatty Phone Plug
CLEARANCE 1/4" Mono Big Fatty Phone Plug
Parts ExpressPart # 092-358
The Big Fatty 1/4" connector is perfect for the large diameter wire used in high power speaker applications.
  • Connector type: Big Fatty™ 1/4" mono
  • Shell: Nickel plated machined brass
  • Dimensions: 3.4" L x 0.68" O.D. (barrel)
  • Cable entry: 11.2 mm (0.44")
Rean NYS2202 1/4" Mono Jack Thick Panel
Price: $2.24Part # 092-126
See all items in 1/4" Phone Connectors
We'll send you an email when 1/4" Mono Big Fatty Phone Plug is back in stock or available for preorder.
The line of high performance Pro Sound connectors offer superb build quality, fit and finish at an incredible price! The Big Fatty™ 1/4" connector is perfect for the large diameter wire used in high power speaker applications. Features heavy-duty nickel plated brass construction for performance and durability, thick gauge shell for superior shielding, and heavy gauge solder points and grounding tab (unlike the thin, flimsy tabs you'd typically find on a connector in this price range.) Includes plastic insulator sleeve. Sold individually.
Specifications: • Connector type: Big Fatty™ 1/4" Mono • Shell: Nickel plated machined brass • Dimensions: 3.4" L x 0.68" O.D. (barrel) • Cable entry: 11.2 mm (0.44").
Part Number092-358
UPC844632015755
Weight0.06
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
