Sure PS-SP11183 12 VDC 17A 200W Regulated Switching Power Supply
Sure Electronics PS-SP11183 12 VDC 17A 200W Regulated Switching Power Supply
Brand:|Model: PS-SP11183
This 12 volt DC, 17 amp regulated power supply is capable of up to 200 watts of output. Switchable 90-264 volts AC input. UL recognized design.
List Price$59.99
You Save28%
Buy 4+$40.75
Part # 320-3149
  • Adjustable 10 to 13.5 VDC regulated output with 17A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Great for electronics projects, especially amplifiers
  • For use with electronics that demand up to 200 watts of power
This power supply is ideally suited for use with amplifier projects. With a regulated output of 12 volts DC, and current capacity of 17 amps, this power supply is the perfect partner for amplifiers with of up to 200 watts of output on tap.
Voltage input can be switched for use with 110 or 240 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Power cable included. UL recognized design. Output voltage is adjustable from 10 to 13.5 VDC.
Note: Minimum recommend power wire gauge is 16 AWG.
Specifications: • Input power: Switchable between 90-132 VAC and 180-264 VAC, 47-63 Hz • Output power: 12 VDC, 17A • Dimensions: 8.46" L x 4.53" W x 2" H.
  • BrandSure Electronics
  • ModelPS-SP11183
  • Part Number320-3149
  • UPC848864002675
  • Product CategoryPower Supplies
    (1 Reviews)
  • Weight1.9 lbs.
View similar products to the Sure Electronics PS-SP11183 12 VDC 17A 200W Regulated Switching Power Supply
in the Power Supplies product category.
Sure Electronics PS-SP11183 12 VDC 17A 200W Regulated Switching Power Supply is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Simple designThe power supply itself worked great, I used it to run a long continuous led strip. The only complaint I have is that it doesn't have any type of bracket for mounting it to a wall or shelf.
Date published: 2014-05-08
  • 2015-11-26T06:35CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_320-3149, PRD, sort_mostRecent
please email  for a prompt reply.
I want to run my subwoofers inside. So this will be able to convert the ac power source in my house to a dc power soure ? And would I need my car amplifier with this or can I just run it to my speakers and stero?
Asked by: Brent123
This will convert 110 volt house power to 12 volt dc. It may be able to power you amplifier at medium to low power. This supply only delivers 200 watts total so the amplifier would be delivering less than that. it may be less money and trouble to use an amp dedicated to 110 volt operation
Answered by: Chrisf
Date published: 2015-03-31
I'm doing this project for the club I work for and I will be running 50ft and 33ft of your led strip lighting and need some help with the parts I will need. I guess help with the power supply and amplifier?
Asked by: Schneider
Please contact our tech support for more help with this question, or 800-338-0531 x1.
Date published: 2014-09-22
Would this be a good power source for a 1000W 4 channel car amplifier?
Asked by: TannerFromNC
This will be enough to get some output from the amplifier although the power supply can only produce about 200 watts of output potential. You will need something with much higher output to get the most from the amplifier. The biggest power supply we have is a 40 amp which you can see below.
if I connect just 1 or 2, 12 volt relays to this supply will it activate
Asked by: daylightdon
It is a little vague what you are trying to accomplish.This Power supply runs off of house hold mains voltage 110VAC 60Hz in the US (220VAC 50Hz in Australia, just have to select you application with a switch on the device). Be very careful with House Mains Supply. I suggest adding a switch and fuse on your hotline.If you want to use a relay to switch the mains, you will need to find one rated for 120VAC at a minimum 20 Amps. Just be aware that switching power supplies when first turned on can have an inrush current of 5 times or more of its normal draw for several milliseconds.If you would like to use 12VDC relays for devices powered by the Power Supply, just check your devices max current requirements (ie a 30Watt amp at 12VDC will pull ~2.5Amps max) and use a relay rated for about twice that (so a 5 Amp relay).Best of luck on your project.
Answered by: JDoyner
Date published: 2013-08-19
  • 2015-11-26T07:14CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_320-3149, PRD, sort_recentQuestionsFirst
Get Sales Flyer
