PRV Audio 15W1600 15" High Power PA Woofer 8 Ohm
Brand:|Model: 15W1600|Part # 294-2742
Choose the PRV Audio 15W1600 15" woofer for use as a replacement speaker in high-end speaker cabinets. Its class leading power handling, subwoofer-like low frequency reproduction, and high sensitivity means more output for your driver dollar!
List Price$187.48
You Save20%
$149.99
Part # 294-2742
  • Extreme forced-air cooling system for hours of use without failure
  • 4" voice coil on a Kapton® former for 800W of power handling
  • 7.6 mm of Xmax and a low Fs for playing below 40 Hz with authority
  • Ribbed paper cone captures that "classic tone" of high-end speakers
  • High 97 dB sensitivity
PRV Audio's 15W1600 15" professional audio woofer is designed for high-end performance, in both PA and high SPL mobile audio systems. From the dual spider suspension mounted on a cast aluminum frame, 4" diameter voice coil with Kapton® former and an impressive 7.6 mm of Xmax, to the forced air ventilation system that keeps the motor cool even during massive power spikes, the 15W1600 was designed to compete against cost-no-object 15" woofers, and even subwoofers, well outside of its price point.
A non-pressed ribbed pulp cone offers a natural classic tone found in most high-end PA speaker cabinets, making the 15W1600 driver an ideal replacement woofer or subwoofer in both ported and sealed speakers. A special compound is incorporated into the the woven cotton surround to resist against wear for years of use. Spring-loaded speaker terminals make quick connection a breeze.
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)1600 Watts
  • Impedance8 ohms
  • Frequency Response50 to 1,500 Hz
  • Sensitivity97 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)53.6 Hz
  • DC Resistance (Re)5.8 ohms
  • Voice Coil Inductance (Le)1.78 mH
  • Mechanical Q (Qms)13.77
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.42
  • Compliance Equivalent Volume (Vas)3.25 ft.³
  • Mechanical Compliance of Suspension (Cms)0.067 mm/N
  • BL Product (BL)24.13 Tm
  • Diaphragm Mass Inc. Airload (Mms)130.8g
  • Maximum Linear Excursion (Xmax)7.6 mm
  • Surface Area of Cone (Sd)984 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.27"
  • Baffle Cutout Diameter14"
  • Depth5.51"
  • # Mounting Holes8
  • Sealed Volume1.26 ft.³
  • Sealed F3101 Hz
  • Vented Volume3.16 ft.³
  • Vented F353 Hz
  • BrandPRV Audio
  • Model15W1600
  • Part Number294-2742
  • UPC799928733595
    (4 Reviews)
  • Weight27.25 lbs.
