290-468_ALT_0
290-468_ALT_1
Eminence Legend B810 10" Bass Guitar Driver 32 Ohm
Brand:| Model: Legend B810
The Legend B810 is a 32 ohm, 10" stamped frame bass guitar driver. A true classic design with some important updates.
290-468
Weight: 8 lbs.
IN STOCK
$79.99
Part # 290-468
The Legend B810 is a 32 ohm, 10" stamped frame bass guitar driver. A true classic design with some important updates: an M-roll surround for higher excursion and less cone breakage, a double-dipped cone apex for an extra-strong cone neck, and a bumped back plate for greater voice coil travel before damage. Eminence's B810 offers classic sound with some modern features added to make a driver that will sound great and last a long time. Works well in small sealed enclosures and in some vented applications. The ultimate driver for classic 8 x 10" bass guitar cabinets. Use the Legend B810 four at a time, connected in parallel, to get an 8 ohm load. Eight of them connected in parallel will result in a 4 ohm load.
Specifications: • Power handling: 150 watts RMS/300 watts max • VCdia: 2" • Le: 2.72 mH • Impedance: 32 ohms • Re: 27.5 ohms • Frequency range: 49-5,100 Hz • Magnet weight: 30 oz. • Fs: 52.07 Hz • Sensitivity: 92.7 dB 1W/1m • Vas: 2.34 cu. ft. • Qms: 13.91 • Qes: 0.68 • Qts: 0.65 • Xmax: 4.7 mm • Dimensions: Overall diameter 10.11", Cutout diameter 9.13", Depth 4.08".
  • TypeBass Guitar
  • Nominal Diameter10"
  • Impedance32 ohms
  • Power Handling (RMS)150 Watts
  • Magnet MaterialCeramic Ferrite
  • BrandEminence Speaker
  • ModelLegend B810
  • Part Number290-468
  • UPC876358001705
  • Product CategoryGuitar Speakers & Bass Guitar Speakers
    (1 Reviews)
  • Weight8 lbs.
View similar products to the Eminence Legend B810 10" Bass Guitar Driver 32 Ohm
in the Guitar Speakers & Bass Guitar Speakers product category.
Eminence Legend B810 10" Bass Guitar Driver 32 Ohm is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Great for bass ampsThis is great for cabinets with four or more speakers. With 32 ohms wiring four in parallel bring it to a eight ohm load. Just do not use a keyboard dropped below rated feq. of about 57hz. This speakers can handle high spl's.
Date published: 2011-02-17
I have the original Ampeg bass cab that used NINE 10", 2 ohm drivers (in groups of three, in three separate chambers). How would I wire these?
I have the original drivers that need to be re-coned. Is that possible (2 ohm voice coils)? If the 32 ohm drivers could be wired up, that would be great. Any advice welcome.
Asked by: HaroldArnold
The 9 x 10" cabinet was part of the V-9 300 watt guitar amp setup from the Seventies. Yes, really: a guitar amp version of an SVT. Be glad Ampeg didn't make very many of them.And the V-9 was a ported cabinet, but the SVT 8 x 10" was sealed. Go figure.
Answered by: Some other guy
Date published: 2014-03-05
I have a Gallien Krueger Goldline GLX410 and have 2 blown speakers. Can I replace them with the Eminence Legend B810 10"?
This is the GLX410 specs:Configuration: 4 x 10" Paragon Goldline loudspeakers.Power (RMS): 400WPower (Program): 800WImpedance: 8 OhmsSensitivity: 100dBMax SPL: 126dBFrequency Response: 30Hz to 7kHz
Asked by: Goma
You have several options. You can recone/replace the voice coils on the two woofers - many shops perform this service. They also change woofer surrounds as they age and crack. Or you can change all 4 drivers, not just 2. You would need to measure the internal volume, divide by 4, and then find a woofer that matched that volume for performance. This is done with a box calculator using the T/S parameters with each woofer spec. If you have a port - it may need to be modified.
Answered by: MarkAJH
Customer projects that include: Eminence Legend B810 10" Bass Guitar Driver 32 Ohm
