  • Gold Binding Post Terminal Cup with 2-Way 4,000 Hz Crossover
BUYOUT Gold Binding Post Terminal Cup with 2-Way 4,000 Hz Crossover
Factory BuyoutsPart # 299-4030
Model: V-33XO-0001
With high quality gold plated binding posts, this 3-5/8" x 3-1/8" terminal cup it a great deal by itself. However, the attached 2-way 4,000 Hz 12 dB/octave (8 ohm woofer and tweeter) crossover network makes it an amazing deal.
  • Gold plated binding posts accepts banana plugs, spade connectors, or up to 10 gauge wire
  • High quality 2-way crossover is suitable for countless woofer/tweeter combinations
  • Terminated woofer/tweeter leads makes wiring and connections easy
  • Included gasket ensures an airtight seal to your enclosure
We'll send you an email when Gold Binding Post Terminal Cup with 2-Way 4,000 Hz Crossover is back in stock or available for preorder.
With an attached 2-way, 4,000 Hz 12 dB/octave crossover and gold plated binding posts, this 3-5/8" x 3-1/8" terminal cup makes it easy to build your own speaker system in no time. The high quality gold plated binding posts will accept banana plugs (standard 3/4" spacing for dual banana plugs), spade connectors, or up to 10 gauge wire. The attached crossover will produce a 12 dB/octave crossover (high pass and low pass) at 4,000 Hz when using an 8 ohm woofer and tweeter. With a laminated iron core inductor in series with the woofer and a Mylar capacitor in series with the tweeter, you can expect this crossover to produce clean output while adding very little to the original signal. In addition, the tweeter section of the crossover will lower the output of the tweeter by 3 dB, making it possible to match a high efficiency tweeter to a woofer with lower efficiency.
Dimensions:• Overall size: 3-5/8" W x 3-1/8" H x 3" D • Cutout: 2-7/8" W x 2-1/8" H
Wiring connections:
Yellow = Tweetrer +
Grey = Tweeter -
Red = Woofer +
Black = Woofer -
BrandFactory Buyouts
ModelV-33XO-0001
Part Number299-4030
UPC848864058603
Weight0.35
ConfigurationIncludes Connector Dish
Crossover Type2-Way
