  • USB-C Mountable Extension Cable for Power/Data
Parts ExpressPart # 130-033
Extend your USB-C power/data jack with this 1 ft. extension. Chassis mount female lets you access the port outside your project.
  • Extend USB-C ports from inside a project to access outside the project
  • Includes two M3 x 7.5mm screws that thread into the female USB-C mount for easy installation
Your Price: $5.98
Save $4.01 (40%)
141 In Stock
We'll send you an email when USB-C Mountable Extension Cable for Power/Data is back in stock or available for preorder.
Order in the next 7 hr 39 min to ship today. Details
Many small 5 VDC powered amplifier boards have a USB-C power port. Sometimes it's hard to mount the board so you have access to the port. With this USB-C extension you're able to mount the amp board deep inside the project and then make a two small holes in the enclosure 17 mm apart to securely mount the female port with the included screws. Make a hole for the female USB-C that's 10 x 4 mm. This way you are able to plug and unplug externally without having to take the top off your project.
Part Number130-033
UPC848864074344
Cable Length1feet
Cable TypeUSB Type C Extension Cable
Jacket ColorBlack
