PRV Audio D3500TiH-Nd 2" Neodymium Horn DriverFeaturing a cutting-edge design, the D3500TiH-Nd Titanium Hybrid compression horn driver is elevated by its distinctive 138 mm (5.43″) diameter neodymium ring magnet. This innovative magnet design not only reduces the overall size but also renders it ideal for front mount applications. Pushing the boundaries of modern technology, this exceptional driver boasts a non-standard 3.5″ voice coil seamlessly connected to a pure titanium diaphragm supported by an exclusive Mylar suspension.
The Hybrid diaphragm of this driver ushers it into a new realm of high output and remarkably smooth mid-range frequency response. This versatility equips it to thrive in an array of high output audio contexts, particularly vocal reinforcement scenarios. Its applications span PRO, high-end monitors, high-output home audio speakers, car audio setups, and PROAudioOnWheels® audio systems.
400 watts RMS Musical Power (when used with the recommended 1000 Hz, 18 dB/octave high pass crossover).
300 watts RMS Musical Power (when used with the recommended 800 Hz, 18 dB/octave high pass crossover).
The distinct diameter neodymium driver permits effortless front mounting, streamlining the installation process without necessitating the detachment of the driver from any WGP14-50 Horn. With a diameter measuring only 5.43″, it offers ample clearance to snugly fit within the 5.69″ baffle cut required for our 2″ exit horns from the WGP14-50 Series.
Positioned to bridge the gap between compression drivers featuring 3″ and 4″ voice coils, this driver showcases a 3.5″ voice coil paired with a specially dimensioned neodymium magnet, tailored for straightforward front mount installation. The outcome is a compact yet incredibly powerful driver, adeptly addressing critical component spacing and weight considerations.
The intelligently engineered Hybrid Titanium diaphragm upholds sound precision while the non-fatigued suspension guarantees enduring performance. This diaphragm is seamlessly integrated with a high-energy motor, ensuring remarkable output across the driver's usable bandwidth for seamless, dynamic sound over an expansive range.
Impressively, the D3500TiH-Nd attains a remarkable 110 dB output with just 1 watt of input power (2.83V) when measured at one meter. This level of output certifies its suitability even in the most acoustically demanding environments.
Mounting hardware is included.
