  • Crown XTi 6002 Power Amplifier 2 x 2100W at 4 Ohms
Crown AudioPart # 245-411
Model: XTi 6002
The all-new XTi 2 Series amps by Crown continue to set the standard for unmatched performance and value, delivering the goods night after night without breaking a sweat. Crown's 6002 XTi 2 Series power amplifier has up to 6,000 watts power.
  • Peakx Plus™ Limiters provide the ultimate in system performance and protection by allowing full control over threshold, attack, and release
  • Enhanced Subharmonic Synth section provides user control over frequency, gain and filter type for system-specific tuning
  • 3 User-defined fan mode controls – normal, early and fullspeed – for matching fan performance to a specific application
  • New system monitoring provides software visibility of AC line voltage and power supply temperature
  • Integrated cast-aluminum handles for easy handling and enhanced durability
  • Locking power cord clip provides a secure connection between the amplifier and power cord
  • Updated HiQnet Band Manager™ and System Architect™ control software
Your Price: $2,995.00
MSRP: $3,743.75
Save $748.75 (20%)
Out of Stock
We'll send you an email when Crown XTi 6002 Power Amplifier 2 x 2100W at 4 Ohms is back in stock or available for preorder.
Special Order Items ships in 20-30 days
The all-new XTi 2 Series amps by Crown continue to set the standard for unmatched performance and value, delivering the goods night after night without breaking a sweat. There's no debate – when you choose Crown’s XTi 2 Series, you’re choosing one of the most powerful and innovative amplifiers on the market today. Crown's 6002 XTi 2 Series power amplifier has up to 6,000 watts power.
With such innovations as a universal tracking switch-mode power supply and a fully integrated suite of speaker processing tools, these amps are at the top of their class when it comes to thermal efficiency and system flexibility. You also have greatly improved control capabilities. The addition of Peakx Plus™ Limiters gives you full command over threshold, attack and release, and we enhanced the Subharmonic Synth so you can easily manage frequency, gain and filter type, allowing for application-specific tuning.
Plus, you'll now be able to tailor fan speed for specific applications and have software visibility of the power supply temperature and AC line voltage. Combine all of that with integrated cast-aluminum rack handles for maximum durability and portability and you have the power to move you – and the world.
Integrated Processing
  • Input EQ: 6 parametric filters per channel with adjustable Q, ±15 dB boost/cut. Also adjustable high and low shelving filters. This 8-filter EQ section can be bypassed
  • Crossover filters: Highpass and Lowpass per channel. Butterworth 6/12/18/24 dB per octave. Linkwitz-Riley 24/48 dB per Octave. Also includes ±15 dB bandpass gain and polarity control
  • Output EQ: 8 parametric filters per channel with adjustable Q, ±15 dB boost/cut. This 8-filter EQ section can be bypassed
  • Delay: For signal alignment of driver; 50 mS of total delay
  • SubHarmonic synth: Takes the low-frequency content of the input signal and "synthesizes" a new signal that is the same as the input signal but one octave lower. The new synthesized signal is then mixed with the original signal to create the effect. New: Users now have control over frequency, gain, and filter type
  • Peakx™ plus limiter: User defeatable limiter that allows users to control Threshold, Attack, and Release times
  • Presets: 30 total presets, 29 of which are user-definable
    Controls
  • Level: Two front-panel rotary level controls, one for each channel
  • Power switch: On/Off switch applies AC power to the amplifier
  • Sel/Prev/Next Buttons: Three buttons near the LCD screen that are used to access menu items and front panel lockout
  • LCD Screen: Backlit liquid crystal display that shows preset and processing status
    Input/Output Connectors
  • Input connectors: XLR, one per channel
  • Link/Out connector: Loop-thru signal from input connector for linking another amplifier, one per channel
  • Output connectors: Two Neutrik® Speakon® NL4MP output connectors, Channel-1 Speakon® is wired with Ch. 1 and Ch. 2 outputs for use with optional single 4-conductor cable, Two binding post outputs (in parallel with Speakon® connectors)
  • HiQnet™ USB connector: Type B, connects to HiQnet™ network
    Construction
  • Chassis: Steel
  • Front panel: Cast-aluminum
  • Cooling: Proportional speed fan with front-to-rear airflow
    Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 1,200 watts x 2 (8 ohms), 2,100 watts x 2 (4 ohms), 3,000 watts x 2 (2 ohms) • Output power, bridged mono mode (EIA 1 kHz): 4,200 watts x 1 (8 ohms), 6,000 watts x 1 (4 ohms) • Distortion (typical): <0.5% @ 8 and 4 ohms, <1% @ 2 ohms • S/N ratio (below rated 1 kHz power @ 8 ohms): 103 dB (A weighted) • Frequency response (at 1 watt, +0 dB, -1 dB): 20 - 20,000 Hz • Crosstalk (below rated power): 20 - 1,000 Hz: >70 dB • Input sensitivity (for full rated power at 4 ohms): 1.4V • Input impedance (nominal): 20k ohms balanced, 10k ohms unbalanced • Maximum input signal: +22 dBu typical • Damping factor (8 ohms, 20 Hz - 1 kHz) : >500 • Dimensions: 3.5" (2RU) H x 19" W x 16.2" D • Weight: 24 lbs.
    BrandCrown Audio
    ModelXTi 6002
    Part Number245-411
    UPC871015005478
    Weight30
    Output Channels2
    Weight Range20 to 29 lbs.
  • Specifications
