  • Celestion G12T-75 12" 8 Ohm Guitar Speaker 75W
CelestionPart # 294-2270
Model: G12T-75
Celestion's G12T-75 8 ohm speaker is seen by many as the ultimate incarnation of the original Celestion G12M model – a Greenback on steroids! With its aggressive and spiky tonal qualities, the G12T-75 has featured extensively in cabinets like the legendary Marshall 1960.
Your Price: $159.00
MSRP: $238.50
Save $79.50 (33%)
Only 1 In Stock
We'll send you an email when Celestion G12T-75 12" 8 Ohm Guitar Speaker 75W is back in stock or available for preorder.
Order in the next 15 hr 20 min to ship today. Details
Featured in the world's top selling 4x12 cabinet, the G12T-75 is a high powered rock player's dream. The best selling guitar speaker of all time, the G12T-75 is in fact remarkably versatile, staying clean at thunderously high volume levels. Built to meet the demands of high gain amplifiers, the G12T-75 combines a huge, tightly controlled low-end and aggressive mid-range with a softened top-end that adds a welcome sweetness to overdrive, distortion and aggressive upper harmonics. These are the characteristics that make the G12T-75 the weapon of choice for Yngwie Malmsteen.
Overall Specifications: • Nominal diameter: 12" (305 mm) • Power rating: 75 watts • Nominal impedance: 8 ohm • Sensitivity: 97 dB • Chassis type: Pressed steel • VCdia: 1.75" (44.5 mm) • Voice coil material: Round copper • Magnet type: Ceramic • Frequency range: 80-5,000 Hz • Fs: 85 Hz • DC resistance, Re: 6.77 ohm.
Mounting Information: • Diameter: 12.2" (309 mm) • Overall depth: 5" (127 mm) • Magnet structure diameter: 5.7" (145 mm) • Cut-out diameter: 11.1" (283 mm) • Mounting slot dimensions: 0.31" (7.9 mm Ø) • Number of mounting slots: 4 • Mounting slot PCD: 11.7" (297 mm) • Weight: 7.7 lbs. (3.5 kg).
BrandCelestion
ModelG12T-75
Part Number294-2270
UPC739894378154
Weight9.1
Nominal Diameter12"
Power Handling (RMS)75 Watts
